Run Active users report
Open Panviva Manager An administrative role responsible for managing workflows, feedback, and document assignments..
The Document Management window displays.
Click Analytics.
The Analytics window displays.
Select Active users report.
Complete the following fields, as necessary:
Note: All fields are optional. If you do not complete any fields, the report pulls data using the default values shown in the fields. To ensure you get the data you want, be sure to complete the appropriate fields (i.e. apply filters).
Field
Instruction
Users
Click
Select the appropriate user(s).
Click Add user(s).
Roles
Click
Select the appropriate role(s).
Click Add role(s).
Date from
Select the start date.
Date to
Select the end date.
Time interval
Select Daily, Weekly or Monthly.
Click Run analytics. A chart displays with your results.
Note: Hover over a data point to see the date and active user count. Scroll down to see more details.
To toggle between chart and data views:
To see the... |
Then... |
Chart view |
The view scrolls to the chart. |
Table view |
The view scrolls to the table. |
To zoom in on an area of the chart:
Press and drag over the area of the chart you want to examine in more detail. Hint.
Click Reset zoom to return to the original setting.
Choose the next step:
To...
Then...
Print the report
Click Print
Export the report as a PDF
Click Export to PDF
Export the report as an Excel spreadsheet
Click Export to Excel
Export all of the analytic's data as a CSV
Click Export full data
The report runs as a background task.
Click
Select Background tasks.
Select the report.
Click Download.
Click Reset filters to run a new report.
To save a search filter:
You have applied filters to an analytic report and you want to use those same filters again in the future.
Note: You can save multiple filters for any analytics report.
Click Save As. The Save Filter As dialog box displays.
Enter a Name for the search filter.
Click Save .
The filter is listed in the Saved filters field.
Note: The next time you run this analytic, you can select the filter and the filters you had applied populate the fields. You can then click 'Run analytics'.
To use a saved search filter:
Select the appropriate Analytics report.
Select a saved filter. The appropriate fields populate with the saved filters.
Note: You may still add or change filters as needed.
Click Run analytics. The analytics report displays.
